MikroTik - Failover - TPLink
Проблемы администрирования сетей
Artsemenaname
Сообщение Artsemenaname »
Good Day
I am fairly new to Mikrotik and need help with the following please.
1 I have a mikrotik router MikroTik RB9412nD hAP lite HAP Lite router, as well as a TP-Link router now i know the HAP Lite also has wireless in but the antennas is not as strong as the TP-link one, so would like to bridge the two and be able to use the TP-link wireless which also connects with the TP-link extender on my network.
2 I have two different ISP DSL accounts i would like to setup on the router, one being used for the purpose of a fail over should one of the ISPs experience issues etc.
How would i go about setting up the above ? I would really appreciate it if someone could help me.
Thanks for reading and in advance.
Аватара пользователя
sanglyb
Site Admin
Re: MikroTik - Failover - TPLink
Сообщение sanglyb »
Hi.
1 - simply put TPLink in AP Mode, and connect it to Mikrotik's briged lan port. If you wish, you can set static IP address for ap, on AP itself, or make a reserve in IP-DHCP Server - Leases.
2 - you should manually set distance to default gateway (your provider). This can be done in IP-Routes, if provider gives you static ip, or in ip-dhcp clietnt, if dynamic, or in properties of PPP connection.
